Draw Flattened Pixmap Issue
Still pending as of LV 2012.0f3, it would seem...
Message 11 of 17
(1,178 Views)
Amaizing this stuff is STILL not resolved in LV2020 10years later...
Message 12 of 17
(648 Views)
Just not to nag, I'll append possible solution.
Adjust Color table range from 0-255 to 0-160 (this is range I found to be working without bluring the image) and data range from wahtever it is to 0-160.
Message 13 of 17
(643 Views)
I would rather use an intensity plot than a picture-control as indicator,
as there wont be no zooming issues, as described.
Message 14 of 17
(619 Views)
use the cursor to counter check grayscale pixel values
use the intensity plots z-scale property like this:
- z.scale : autoscale = true (default)
- z.scale : interpolate? = true (default)
- z.scale : ignore color arry? false (default)
## one-sided thresholding
## two-sided thresholding
Message 15 of 17
(613 Views)
I am not quite sure why you bring up and describe intesity, when discussion is about pixmap, but whatever.
Also there was no question about thresholding whatsoever.
Message 16 of 17
(113 Views)
Go back to Message 2 of 16 and check for yourself
that is what you should expect.
the NI Picture Control Toolkit by National Instruments is no longer actively developed.
It is in a legacy / maintenance-only status.
the same is true for the Intensity plot
because the intensity plot is the better option, IMHO, when dealing with false-color images with low color depth  (2^8 = 256 colors)
especially when two sided ranges are a must.
if you ask NI, they will probably advise you to use the Vision Toolkit
Message 17 of 17
(54 Views)
