07-20-2006 08:15 PM
07-21-2006 03:46 PM - edited 07-21-2006 03:46 PM
I’m not too sure what the exact problem you are encountering is, and I see a sequence structure but I don’t see how it comes in to play here. If your question is about how to add multiple plots to an XY graph, I would take a look at the context help window which gives good indication about how to add plots to the graph. Each plot consists of a “bundle” of arrays where each element in the bundle is an array of data values. To add plots to the graph, wire each ‘bundled’ plot to the “build array” VI. Make sure to expand the plot legend in the graph to account for the multiple plots that will be displayed.
Before troubleshooting the XY graph, I would make sure that you are getting the appropriate data from your Data Acquisition device. Are you certain that you have set up your DAQ portion of code correctly, and that the data coming from the device is in the proper format?
Thanks for posting to the forms, please let us know if you have any additional information or questions on this. Have a great weekend!
Message Edited by Travis M. on 07-21-2006 03:46 PM
