Drawing a Heighway Dragon curve using the L-system method.
It looks like the same file to me.
Message 11 of 14
(954 Views)
Woah good work. If I want to run it so each line writes individually to the graph at a rate specified by the user how could I do that?
Message 12 of 14
(941 Views)
You would need to move the graph (and the function to trim the extra elements) inside the loop and add some timing to the loop. Not sure how well it would work for large amounts of data.
Message 13 of 14
(938 Views)
Here's my (very old) Koch curve code…
Message 14 of 14
(927 Views)
