Drawing a curved line of any shape from circular arcs
To generate a LabVIEW application for drawing a curved line of any shape from circular arcs. The program will allow you to:
◮ data entry (circle radius, circle arc angle) for all components
◮ saving/loading data regarding components using a text file (each line in the file contains the data for a single component)
◮ drawing the curved line.
(2,019 Views)
Hi Jevr,
and what is your question?
General comments:
  • Attach what you tried so far and explain where you are stuck.
  • We cannot debug/run/edit images using LabVIEW…
  • We usually don't do your homework…
(2,008 Views)
Hi!
Thanks for response.
I tried to generate so far the multi arc`s in the same graph, but I don`t have any idea how to make them to be connected , now I have the same origin for that 3 arc.
The question is: How can I change the position of the arcs to build something like sin wave ?
Thank you!
(1,981 Views)
You need to be significantly more specific.
How exactly should they be "connected"? There are infinite possibilities. One possibility would be to make the output tunnel concatenating instead of indexing..
You cannot create a sine wave by connecting arcs. can you draw what you like to see?
Please attach your VI instead of picture.
(1,963 Views)
I attached the .vi and a draw of a 3 arcs.
I need to have a base arc and at the end of the first one to start the next one, and so on.
For now I am happy that I have 3 arcs in the same graph :))
I hope you understand what I am trying to do.
(1,821 Views)
Accepted by Jevr
You could just align the first point of the new graph with the last point of the previous graph.
(1,893 Views)
whoooooooo, thanks! I understand now, I manage to make it work on my side and complete with the rest of that 2 requests. Thank you very much, I was stuck for a few hours and ask many people.
Have a nice day!
(1,881 Views)
