Drawing smooth circles in labview
Hi
I am using the 'Draw Circle by Radius' VI to draw a pie chart inside a picture box. Its all fine, except that the circle edges are not exactly smooth (see the attached pic).
I tried looking for it on the net, but couldn't find anything of much use.
Any ideas on how to make the edges nice and smooth?
(4,097 Views)
Hi
The circle is not smooth as no anti-aliasing is done with the picture drawing VIs. To get it to appear smooth you would need to implement an anti-aliasing algorithm in the picture control. This is not something I have ever seen done. You could download MSChart from Microsoft, it is just a free .NET component and code that you can download. Thoric has done a great example here https://decibel.ni.com/content/docs/DOC-9946 that you could start with to draw the pie chart for you.
Mike
(4,079 Views)
Accepted by pranjall
Hi
Mike
(4,078 Views)
Ohhk....this is strange, sad and unfortunate that a platform like LabVIEW doesn't have something as obvious as this.
(4,003 Views)
