Drawn Circle on Intensity Graph is not centered on cursor
Hello! I'm working on a RoI integration VI which involves a pair of concentric circles where everything in between the two would be summed up. The mathematical portion is working perfectly but I am having difficulties with implementing the "Draw Circle by Radius" VI on my intensity plot to visually inform the user where exactly are their integration circles. What am I doing wrong below?
(3,144 Views)
I think you are getting coordinates from the top left of the screen, but the picture functions are in pixels measured from the top left corner of the graph.
(3,115 Views)
Accepted by lukewarmcoffee
Dr Powell is right - you have an offset because of the coordinate systems. You need to subtract the location of the top-left point of the Draw Area (not the bounds of the graph)
Code with Waveform GraphCode with Waveform Graph
When I tried this with an Intensity Graph, I initially didn't have any luck. It seems as though with no data plotted, it doesn't come in front properly. Perhaps a bug?
With the code added below to set the graph data, I got the expected outcome. (This shouldn't be a problem for you because you already have valid data, but I thought it worth mentioning).
GCentral
(3,069 Views)
Both suggestions (and sample code) fixed the problem! Thank you!
(3,003 Views)
