Dresser DXD digital pressure transducer driver became slow with upgrade to 2010
Hello Forum,
I have been using Dresser DXD digital pressure transducer drivers with LabVIEW 2009 without any problems. Recently I upgraded LabVIEW to 2010 and I noticed that data acquisition using the driver became slow and it returns a warning "Dresser DXD default setup is not supported". The warning code is 1073479936. I could not locate this code in the shared folder under the NI installation folder. Do you know what could be the problem with the driver and how I can fix it.
Many thanks in advance,
Zacharia
(2,819 Views)
Accepted by topic author zacharia01
Hello forum,
I could solve the problem with slow data acquisition by using a simpler serial read-write VI.
Thanks as always for the attention
Zacharia
(2,810 Views)
