Driver and example vi for the Advantest R3765CG
The link for the Advantest R3765CG driver does not work.
Can you find this driver for me? I wouldalso like so example vi's for this instrument also. I am using Labview 5.1
Thank you.
(3,460 Views)
The link below to the driver information page works, but the link to the driver itself is an external link, likely to the manufacturer website, which indeed seems to be broken. This would be a good thing to send and note to instrument.drivers@ni.com as they will likely be interested in fixing it. However, the minumum version of LabVIEW that the driver works with (as noted in the page linked below) is LabVIEW 6.0, and you note that you are using LabVIEW 5.1, so a fixed linked may still not be useful to you.
Link: http://sine.ni.com/apps/we/niid_web_display.download_page?p_id_guid=E3B19B3E9737659CE034080020E74861
Repost if you have any other questions!
Best Regards,
JLS
Best,
JLS
Sixclear
(3,453 Views)
The other thing to try is the R3765 driver here [link removed; driver no longer available] and get someone to first convert it to 5.1 and then make the modifications necessary for the CG model. Unfortunately, I can no longer save to 5.1 as the oldest version of LabVIEW that I have is 6.1 but if you post the llb, I'm sure someone will do it for you.
(3,445 Views)
Just an update:
NI has apparently contacted Advantest about the link; in the mean time you can probably get the driver by contacting Advantest directly! Then, as Dennis suggested, LabVIEW version 6.0 will be able to "save for previous" to version 5.1 for you (provided those VIs can be back converted).
Repost if you get the driver and be sure to attach it!
Best Regards,
JLS
Best,
JLS
Sixclear
(3,440 Views)
how to open block diagram of NIDAQ's example (DAQcard-1200) of 6.9.3 version in labview 7.1
thank you
(3,420 Views)
Duplicate Post
E. Sulzer
Applications Engineer
(3,398 Views)
