Driver for RD-31 and 33 by Radian Research Needed
What kind of read do you want?  Do you want to read how many pulses are output so far?  Do you want to read through an external instrument?
Kudos and Accepted as Solution are welcome!
Message 21 of 28
(1,342 Views)
I would like to read 1 pulse every 10minutes via a Labview program that I made.
Message 22 of 28
(1,338 Views)
You meant you need to read total pulse accumulated once every 10 minutes, right?  I don't have access to that instrument anymore, but from what I remember, you can't read the total numbef of pulse acumulated.  You need to connect a digital input to the digital output of the Radian and count the pulses.
Message 23 of 28
(1,323 Views)
That s right, I want to read the total energy derived from the pulses. Thank you for letting me know that i might be wasting my time trying to do it like that
Message 24 of 28
(1,315 Views)
You could reset the accumulated metrics registers on the RD at the beginning of the test, and then read the accumulated metrics at the end of the test.
Matt Kraus
Message 25 of 28
(1,308 Views)
Hi Yik,
I am looking for a VI for the RD30
Actually I just posted the following in relation to the VIs on the instrument driver page..
http://forums.ni.com/t5/LabVIEW/Radian-Research-Driver-for-RD30/td-p/2285534
Do you think/know if the RD33 VI's wil work for the RD30? Other than changing things like the ID query search string...
Thanks & Regards,
Shane.
Message 26 of 28
(1,221 Views)
The RD-33 and RD-30 differ in accuracy only. The functionality is the same.
Matt Kraus
Message 27 of 28
(1,211 Views)
Hi Matt,
Many thanks for the clarification!
Shane.
Message 28 of 28
(1,208 Views)
