07-01-2008 02:56 AM
07-01-2008 09:14 AM
Hi Kyle,
both models are compatible to the command syntax of the 4145 models. This command syntax is the easiest and fastest way to program these models.
Switch to this mode by:
:SYST:LANG COMP
US
Then check your manual for the DV command, which lets you apply voltage to an SMU, and the TI command for measuring currents.
Have fun
Guenther
07-01-2008 08:01 PM
Can you elaborate on that? I do not know what you mean by switch to that mode. Sorry, I am new to Labview.
07-01-2008 09:20 PM - edited 07-01-2008 09:25 PM
The command has nothing to do with LabVIEW. It is a command from the instrument manual and you can issue it in MAX or write a quick VI to do it.
You say that you haven't been able to get the drivers to work. Can you explain what you mean? Wrong data, no data, error codes? Did you do any testing of some basic commands in MAX? Does MAX even detect the instruments? Because there a couple of different drivers, it would also help if you said which one you are using.
