How to search same but multiple result from multi-line string
Hi, I'm trying to figure out the fatest way to read a text file and reading specific patterns from it, i know that i can read the contents of a file all at once if i don't use read line from the "read from text file" control but how can i process the multi line result?
lets say i have a file that have this content:
line1a_43
line2b_12
line3a_32
line4a_53
line5b_32
line6a_23
i know that if you use read from text file, you'll be given a string result of
"line1a_43\nline2b_12\nline3a_32\nline4a_53\nline5b_32\nline6a_23"
now what should i do to be able to extract the numbers from each line that has "line\d+b" (line with any digit then a letter b)
using a pattern matching technique, i'm expecting to have a result either an array or a string with delimeters similar to this:
12
32
Peter A.
P.S. i know how to do this using read by line technique but if i'm reading a huge file, reading line by line will take longer.
(3,680 Views)
Here's one possibility (LabVIEW 8.5):
(The other case is "a", empty, with the array wired across.)
Message Edited by altenbach on 07-01-2008 06:52 PM
(3,665 Views)
Just a quick thought... hope it works 🙂
Regards.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,662 Views)
Thanks for the sample, with this I was able to extract what i need in less than a second  (~400ms) on two files ~10MB), i made some improvement to it using the search/split string and made it ~200ms. originally it took me 8 seconds using the line by line technique.
thanks a lot,
Peter A.
(3,655 Views)
Hi Peter,
Will you share with us your code? No obligation however 🙂
Message Edited by ian fung on 07-02-2008 11:24 AM
Ian F
依恩与LabVIEW
(3,653 Views)
sure, here it is, i did however took it out from my full block.
there is also a portion of this code that enables me to block off duplicates.
Peter A.
Message Edited by peter.a.azucena@intel.com on 07-01-2008 07:39 PM
(3,649 Views)
