Dsc module to Eurotherm Lin Opc server
Hi. Does anybody have experience in connecting Dsc module to Eurotherm Lin Opc server?
I can connect by data socket, but im having many problems with Dsc module
Thank you
(3,282 Views)
what problem are you experiencing?
Did you try to follow the connecting procedure? http://zone.ni.com/reference/en-XX/help/371618K-01/lvdschelp/create_opc_clnt/
(3,239 Views)
Ciao Lambert_86. Yes I followed
(3,236 Views)
Ciao Lambert_86. Yes I followed procedures. Here some details.
When I chose the server I can see it properly.
When I add new variable, after choosing it I found the first error: EUROTHERM2.JPG
I can solve this problem by manually choosing the variable:
EUROTHERM4.JPGIt is esactly the same variable in the same directory.
The Vi for reading variable:
EUROTHERM6.JPGAfter running Vi:
EUROTHERM7.JPGAnd value is always 0.
using Data socket i can read it properly:
But I think the most usefull information is the Server diagnostic report: it is in italian but i suppose you can read it.
With server explorer i can read the same variable properly.
grazie
Antonio
(3,232 Views)
Hi.
At first I supposed it was a fault of LinOpc configuration, but today I used Matrikon Opc server.
Now I think there is some problems in Labview configuration or something like that.
hope somebody will help me
A
(3,203 Views)
