How to display or catch multiple errors in error cluster output
I have a program in witch I check for errors like this:
I want to see if any of the errors exist in program and display them in error out 2 cluster.
The problem I want to solve is:
If (for example) all three errors exist, I only see Error 3 (code -997) in error out 2 cluster, and other two errors (Error 1, Error 2) I don't see and they are lost.
How to display all errors?
(4,318 Views)
Hi Skoda,
You might:
- concatenate the error strings (the string can grow as long as you like, but the error number/boolean can still only take one error)
- log all errors to a file (I use a FGV aka AE for this task, it even stores the last ~100 errors internally for display purposes)
(4,306 Views)
(4,294 Views)
Another option is to use an array of error clusters.
(4,280 Views)
