Dual-processor with Labview?
I currently have a dual-CPU motherboard system as my Labview development/
data analysis machine, although only one CPU is present. I may soon have the
opportunity to either add a second CPU, or to replace the existing one with
a single faster one, and I'm wondering which way to go to improve
performance. I've done a comparison, and for the price of a single
PIII-1GHz, I could instead by a pair of PIII-850MHz processors.
Probably the two most intensive programs that this machine runs are
1) A vi that reads several thousand datafiles, each of the order of a few
tens of K, does various calculations on the data and saves them to a few new
large files, from which it calls Origin (a graphing package) via DDE to load
these file
s and present the results. Both programs run in parallel- the
numbercruncher opens all the files successively and streams the data
point-by-point through the calculation and out into the destination files.
The graphing program loads each completed destination file as it becomes
available, and as the cruncher does the next set, produces the hardcopy
graphs for the completed set. Obviously a lot of disk IO is involved- the
destination files are a few megs in size.
2) A vi that loads a datafile and interactively allows the user to fit a
combination of many functions to the data, with perhaps up to tens of
parameters to vary to get the best fit. This is very CPU intensive.
What kind of performance increase is seen in general in Labview when going
to a dual CPU system? Does it turn out to be a waste, because of the shared
memory and disk access? I have a suspicion that multi-CPU is only useful if
you have many parallel CPU-intensive routines that can execute entirely
within the local cach
e of the processor, but I don't think I have any such
thing here
(3,683 Views)
Craig,
First off you know that the OS has to support dual procs. This means
NT (and I guess 2000) or one of the Unices.
You will not see a 2x performance increase, it may be more along the lines of
30-50% or so (I have no data to support this however). LabVIEW will take
advantage
of the 2nd proc by doubling the number of threads you can use. As you suspect
though
the bottleneck is in the disk drive and memory. That said you will probably see
improvements
if you run one app on one proc and the UI proc on the other. The entire machine
response
will improve.
I know it is not a hard answer just some info to consider.
Kevin Kent
> these files and present the results. Both programs run in parallel- the
> within the local cache of the processor, but I don't think I have any such
> thing here
(3,683 Views)
Craig,
just a few points I might make - if you are being limited by the disk and
memory transfer rates, you might want to consider a RAID disk array to speed
up the disk transfer rate. If you are being memory bandwidth limited, then
again you might want to consider a processor that uses a 133Mhz FSB (an 850
will only use 100Mhz FSB, the 1000Mhz uses 133Mhz). Only if you are 100%
sure you are being limited by the processor should you move to a dual CPU
setup.
Ben
"Kevin B. Kent" wrote:
>This is a multi-part message in MIME format.>--------------4C49107D6A2F74793D6DFB59>Content-Type:
text/plain; charset=us-ascii>Content-Transfer-Encoding: 7bit>>Craig,>First
off you know that the OS has to support dual procs. This means>NT (and I
guess 2000) or one of the Unices.>You will not see a 2x performance increase,
it may be more along the lines of>30-50% or so (I have no data to support
this however). LabVIEW will take>advantage>of the 2nd proc by doubling the
number of threads you can use. As you suspect>though>the bottleneck is in
the disk drive and memory. That said you will probably see>improvements>if
you run one app on one proc and the UI proc on the other. The entire machine>response>will
improve.>I know it is not a hard answer just some info to consider.> Kevin
Kent>>Craig Graham wrote:>>> I currently have a dual-CPU motherboard system
as my Labview development/>> data analysis machine, although only one CPU
is present. I may soon have the>> opportunity to either add a second CPU,
or to replace the existing one with>> a single faster one, and I'm wondering
which way to go to improve>> performance. I've done a comparison, and for
the price of a single>> PIII-1GHz, I could instead by a pair of PIII-850MHz
processors.>>>> Probably the two most intensive programs that this machine
runs are>>>> 1) A vi that reads several thousand datafiles, each of the order
of a few>> tens of K, does various calculations on the data and saves them
to a few new>> large files, from which it calls Origin (a graphing package)
via DDE to load>> these files and present the results. Both programs run
in parallel- the>> numbercruncher opens all the files successively and streams
the data>> point-by-point through the calculation and out into the destination
files.>> The graphing program loads each completed destination file as it
becomes>> available, and as the cruncher does the next set, produces the
hardcopy>> graphs for the completed set. Obviously a lot of disk IO is involved-
the>> destination files are a few megs in size.>>>> 2) A vi that loads a
datafile and interactively allows the user to fit a>> combination of many
functions to the data, with perhaps up to tens of>> parameters to vary to
get the best fit. This is very CPU intensive.>>>> What kind of performance
increase is seen in general in Labview when going>> to a dual CPU system?
Does it turn out to be a waste, because of the shared>> memory and disk access?
I have a suspicion that multi-CPU is only useful if>> you have many parallel
CPU-intensive routines that can execute entirely>> within the local cache
of the processor, but I don't think I have any such>> thing here>>--------------4C49107D6A2F74793D6DFB59>Content-Type:
text/x-vcard; charset=us-ascii;> name="Kevin.Kent.vcf">Content-Transfer-Encoding:
7bit>Content-Description: Card for Kevin B. Kent>Content-Disposition: attachment;>
filename="Kevin.Kent.vcf">>begin:vcard >n:Kent;Kevin>tel;fax:972-477-4462>tel;work:972-477-4468
>x-mozilla-html:TRUE>url:http://www.usa.alcatel.com>org:Alcatel USA;OXC Hardware
Development>version:2.1>email;internet:Kevin.Kent@usa.alcatel.com>title:Engineering
Technician>adr;quoted-printable:;;MS OLXDV=0D=0A1000 coit Rd;Plano;Texas;75075-5802;United
States>x-mozilla-cpt:;16128>fn:Kevin Kent>end:vcard>>--------------4C49107D6A2F74793D6DFB59-->
(3,683 Views)
