return values of IMAQ GetImagePixelPtr
within LabView 5.1.1 on Windows NT I try to manipulate an IMAQ image with a
C programme using a CIN (code interface node). In LabView there exists the
function IMAQ GetImagePixelPtr which returns a pointer on a pixel of the
image (e.g. imagePtr).
I have defined with IMAQ Create an 8 bit image and the applied IMAQ
GetImagePixelPtr. The returned value of the pointer (*imagePtr) is a very
big number (e.g. 35654414) and not as I supposed an 8 bit integer (something
between 0 and 255) which should reflect the brightness of this pixel.
Does anyone has an idea how I can get the brightness information of each
pixel in C?
Thanks a lot,
Gerd
(3,208 Views)
> pixel in C?
Without being really familiar with these functions, from the
name, I would expect that function to return a Ptr. A ptr to
the pi
xel. To get the value of the pixel, dereference the
ptr. In otherwords, if the ptr variable is pixPtr, then
pixelValue= *pixPtr;
Greg McKaskle
(3,208 Views)
You are right, the function returns a pointer, in the manual it says a
pointer on a pixel of the image. What I don't understand is why the
dereferenced pointer has such a big value, i.e. why pixelValue= *pixPtr=
e.g. 35654414.
Gerd Simons
"Greg McKaskle" wrote in message
news:3A2EF679.DE9F786F@austin.rr.com...
with a
the
very
(something
> > pixel in C?
> the pixel. To get the value of the pixel, dereference the
> Greg McKaskle
(3,208 Views)
"Gerd Simons" wrote in message
news:3a2f4326@pfaff.ethz.ch...
> e.g. 35654414.
> Gerd Simons
what is the C prototype of this function? Maybe it is int* AKA
pointer to a C int? (or unsigned int ... etc.)
What are the parameters? X and Y indices?
If just the pointer to the whole array what I suspect not
knowing the function is that it is actually a pointer to
the image array as raw linear byte array in the memory,
and you have to build some useful access functions around it
if you have for example a bit depth
of 8 than a int* isn't
appropriate! Because if it is dereferenced it is actually reading
the number of bytes of an int AKA 4 bytes (assuming 32 bit
ints. Check your system/compiler manual ...)
/jw
(3,208 Views)
> e.g. 35654414.
What is the variable type that you are dereferencing?
If pixPtr is a long*, then pixelValue= *pixPtr will use
four bytes to determine the pixelValue. If pixPtr is
a short*, then it will use two bytes, if pixPtr is a
char*, then it will use only one byte, and this seems
to be what you are expecting.
So, it sounds like you either need to declare pixPtr
to be a char*, int8*, uInt8*, or some other type that
points to only one byte. Or, you can cast it like
pixelValue= *(char*)pixPtr;
Aren't pointers fun?
Greg McKaskle
(3,208 Views)
