Dumping hex file into pic microcontroller via ICD3
I am able to dump hex files into pic microcontroller using command line utilities that come with MPLAB. But, whenever I have to dump a hex file, I need to go to the ICD3 programmer utility location (in MPLAB directory) and paste the hex file to be loaded there. I tried feeding the address of the hex file in System Exec vi along with other necessary commands but it is unable to track the hex file and displaying an error as "hex file not found"..Is there any way to implement above functionality?
(Sorry I didnt get any replies for this query so I am posting it as a new message)
Message 1 of 21
(6,836 Views)
Can you run the same command in a command window? Is it finding the hex file then?
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 21
(6,835 Views)
No...that is not working either..!!
Message 3 of 21
(6,804 Views)
Accepted by topic author mnx
Oh finally i got it...!!
In order to open a folder/file with <space> in its name, I have to put the entire address in double quotes:"<address>" to make it run using command line..:)
Message 4 of 21
(6,801 Views)
Dear all,
I used the same solution for icd3 via icd2cmd via systemexec. This is working fine on my win xp and win 7 32 bit systems. However on 64 bit systems this isnt working anymore. The script keeps hanging on target connected and is not responding after that message. Anyone experience t
He same issues and have a possible solution for 64 bit systems??
Thanks in advance
Bart bakels
Labview Architect
Message 5 of 21
(6,617 Views)
Can you tell where is this command line? I do need same thing
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 6 of 21
(6,448 Views)
Where I can get this command line arguments. How you make sure this programmed properly.
--Ranjeet
Message 7 of 21
(6,441 Views)
Message 8 of 21
(6,372 Views)
here is what I tried.
http://forums.ni.com/t5/LabVIEW/Command-line-arguemts-expansion-at-run-time/td-p/2593047
I am using this for mass programming. Hence I am doing this using batch mode.
Can you help me out in this?
--Ranjeet
Message 9 of 21
(6,369 Views)
Are you planning to use multiple programmersc(ICD3, Real ICE etc) together for programming or a single programmer with pipelining operation (programming single device at a time)?
Also, do you want to program same type of PIC devices?
Message 10 of 21
(6,366 Views)
