Dumping hex file into pic microcontroller via ICD3
No I want to program multiplie PIC ICs(same part number) using labview.
Just a way ICD3 does
want to repeat the programming for mass PIC ICs programing
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 21
(1,937 Views)
I want to use same ICD3
--Ranjeet
Message 12 of 21
(1,936 Views)
When I discussed this issue with MPLAB they told to use batch mode programming, but only problem here is it will terminat as soon as error occures in between. This I want to avoid
--Ranjeet
Message 13 of 21
(1,931 Views)
It is true that it terminates when it encounters an error. Sadly, you cant change the MPLAB programmer utilities as their functionallities have been defined by Microchip. Though I think some sort of manual supervision will be required to take action based on errors and the rest you can take care in you labview code.
Just to check:
Use system exec vi for programming with C:\Program Files (x86)\Microchip\MPLAB IDE\Programmer Utilities\ICD3 as working directory and C:\Program Files (x86)\Microchip\MPLAB IDE\Programmer Utilities\ICD3\ICD3CMD.exe -P PIC18F4620 -F "<hex file path>" -E -M as the command line.
Message 14 of 21
(1,926 Views)
will this -E-m will be at last?
--Ranjeet
Message 15 of 21
(1,923 Views)
Yes it will be after the hex file path. Please go through the link which I posted for more clarifications and other related commands.
Message 16 of 21
(1,920 Views)
What help I got from microchip peopels they mentioned before path selection?
--Ranjeet
Message 17 of 21
(1,918 Views)
You also using batch mode?
This is not the way it has done in MPLAB application. How they are doing?
--Ranjeet
Message 18 of 21
(1,917 Views)
I have done it practically and it works with the commands which I have suggested to you. Go ahead with that, you will be able to program it.
Message 19 of 21
(1,912 Views)
Ok. Let me try that..Will let you know
Thanks for help
--Ranjeet
Message 20 of 21
(1,904 Views)
