During build there is error
This is discription of error
Error 7 occurred at Build Application.vi >> Dist Cmp Settings to Disk Hier.vi >> Dist Report Read Link Info Error.vi
(3,320 Views)
Hi dhanwanti,
For what it's worth, Error 7 means file not found.
Assuming your App-builder isn't broken, it sounds like LabVIEW can't find one of your source-files .
Try doing a mass-compile (Tools\Advanced) on your application directory or LLB.
Make sure you can locate everything App-builder will need. Smiley Wink
I think "Dist Report Read Link Info Error.vi" is just reporting the problem.
(This VI is part of the App. Builder.  In 6.1 it's in "..\LabVIEW 6.1\project\prodisttool.llb")
Cheers.
When they give imbeciles handicap-parking, I won't have so far to walk!
(3,315 Views)
