ADOdb recordset update
Do anyone knows how to update a recordset in a mySQL DB using LV7.1.1, LabSQL (free library), and ADO?
(4,600 Views)
Are you looking for the SQL syntax or which function to use in LabSQL? The syntax is:
UPDATE table_name [options] SET col_name = expr,... [WHERE clause]
as in UPDATE testres SET meas2 = 2.5 WHERE meas1 < 0
The function in LabSQL to use is SQL Execute. Set the Return Data input to false. You would first use ADO Connection Create and ADO Connection Open.
(4,589 Views)
Thanks a lot, this work. Smiley Very Happy
I'd like to know something about ADO.update method, and the use of variant data
(4,575 Views)
