How to create .mnu file?
LabVIEW Development Guidelines>>Chapter LabVIEW Style Guide:
VI CheckList:
"Create a .mnu file, if the VIs will be used as subVIs. Bu sure to arrange the palettes, name the menus, and hide dependent subVIs. "
How to create a .mnu file??
Certified LabVIEW Associate Developer
(9,153 Views)
Open a new VI, go to tools >> Advanced >> edit palette view
then right click in the finction palette where you want to add Menu/VIs
select "Insert" >> "sub-menu" or "...VIs" then "create a new menu file (.mnu)"
I hope you'll get through 😉
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(9,150 Views)
thanks a lot.
I get it!Smiley Happy
(9,139 Views)
thanks a lot.
(9,138 Views)
Thanjs you TiTou!
(9,138 Views)
