Dynamic Data from a Serial response
I need to set up a waveform graph with a time stamp on the bottom, as per
the NI examples, Graph Adapting to Attributes.vi. My main problem is the
data I need to display on the graph is read in from a serial port, it is
generated by custom hardware, so is not dynamic data. How do I convert this
data into dynamic data to display on the graph?
Tom
I am using Labview 7.1.
(2,737 Views)
Hi Tom
Use the Convert to Dynamic Data function
Hope this helps
David
Message Edited by David Crawford on 01-05-2006 06:18 AM
(2,733 Views)
