Dynamic loading subvi
Hey Guys..
Please help to solve this issue.. Attached a image for ref
Silver_Shaper | CLD
(3,479 Views)
Accepted by Silver_Shaper
Two things, first there is a VI method for opening and closing front panels that is the recommended technique. Second, as written, your code dosen't return any data from the subvi that is being called so if there are errors you will not see them.
Mike....
Certified LabVIEW Architect
LabVIEW Champion
(3,456 Views)
Thanks for your reply sir..
But, I don't have any indicator except error out in the sub vi. Why am using vi server is dynamic load and reduce the memory. If I run the same code as u suggested in method 1 it loads 103 vi & lib in memory.
Silver_Shaper | CLD
(3,452 Views)
First, in the end VI Server doesn't save memory per se. What it does is allow you ti not have your application loaded at once which can save memory at the expense of execution time. (The "subVI" loads ar run time)
Second, when used as in your code the VI gets loaded into memory when you open a reference to it. Once you have that reference no more gets loaded regardless of which methods and properties you manipulate.
Mike...
LabVIEW Champion
(3,422 Views)
