Dynamically loading child class in cRIO
Hello there,
So I am trying to dynamically load child class at run time on my cRIO 9049, but I wonder what path should I give to point to the child class?
(1,826 Views)
Accepted by topic author munirh070
What you need is the path to he *.lvclass or *.llb file of you child class depending on how you saved the class before.
You also should use relative paths whenever possible. Here is a quick example:
(1,762 Views)
