Dynamicly creating frontpanel
How to create dynamicly a frontpanel from a selection? The selection is before runtime, the creating is at runtime from a selection of files and configurations.
Message 1 of 15
(6,683 Views)
I think the question needs explanation
Message 2 of 15
(6,678 Views)
I have a product with 5 possible color schemes. The front panel shows it picture. Instead of making 5 different front panels, I want to make 1 panel that is dynamicly created from a set of settings.
Message 3 of 15
(6,674 Views)
Hi Jo,
you can change colors by using property nodes of the front panel objects - if that is all, what is encoded in your "color schemes"...
Message 4 of 15
(6,664 Views)
I was thinking bout making a parent class with a method "dynamic FP creation". And then the (children) products can inherit this method.
So the parent hold the method (loading the leds, pictures, buttons) and the child hold the config(settings) for the method. Something in that style.
Message 5 of 15
(6,657 Views)
Hi Jo,
that has been asked a lot of times before!
You can:
- use VIScripting: it is only allowed in development environment, but not at executable runtime...
- use a picture indicator to "simulate" all controls/indicators...
- predefine controls/indicators (at reasonable quantity) and enable/show/move them at initialization...
It doesn't matter if you're using OOP or functional approach, you're limited by LV possibilities!
Message 6 of 15
(6,651 Views)
That one can also be done with invisible tabs, with no need to use Enable/Show/Hide property nodes. I have a demo somewhere if the OP wants it. Of course, this method, and Gerd's, assumes you have a reasonable quantity of controls/indicators, as Gerd mentioned.
Richard
Message 7 of 15
(6,645 Views)
Have you considered using a plugin architecture and subpanels. Here is a good example of such an approach.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 8 of 15
(6,634 Views)
Yes please, I like that demo. Happy to learn :).
Message 9 of 15
(6,611 Views)
