color interpolation
Hi everyone,
i want to do the color interpolation on a surface in the first round i do the interpolation with using the Color array in the scene mesh, every thing works fine. The problem starts when i want to pick a point on the surface and based on the new picked point do the color interpolation. So all the vertices's on the meshed surface get interpolation based on the value of new picked point. I found the 3D sensor mapping the problem is that i need to feed in a STL file and what i have is a point cloud, i can make a STL file out of it, but i need to update the coordination after each scans, and it can not be done with using STL, so the input of this express VI should be changed which is itself would be hard.
Any suggestion would be so appreciated.
Cheers
Message 1 of 11
(8,022 Views)
I am sorry but I did not follow what the issue is exactly.
I did look at the NI version and promptly tossed after seeing it load 1000 sub-VI and rewrote it myself using first principles which is probably not an option for you but, if you slow down and explain what you need help with (images will help a lot) we may be able to advise.
That's all I can say now,
Ben
Message 2 of 11
(8,010 Views)
Here is a little vi that does color interpolation. I am not sure if this will help but it could be a start.
Tim
GHSP
Message 3 of 11
(8,003 Views)
I can not open it, because it is in a newer version than mein, can you please save it in older version?
Message 4 of 11
(8,000 Views)
Here you go.
Tim
GHSP
Message 5 of 11
(7,992 Views)
Let me try to formulate my problem again. We start with a surface composed of triangles. To each vertice a color has been assigned.
1. I want to choose an arbitrary point on this surface and assign a color to it ( in the attached picture shown by green color) .
2. The color should be interpolated with all vertices. So the interpolation shouldnt be just done for one triangle, but the interpolation should affect the entire surface.
Message 6 of 11
(7,989 Views)
Hi Trin,
to get your problem straight:
1) You do have colors assigned to the vertices of a surface made up by triangles
2) You want to interpolate the color of an arbitrarily chosen point based on the colors of all available vertices
To do the interpolation based on all available vertices you have to weight the colors of the vertices based on the distance (i.e., euclidean distance) from the arbitrarily chosen point. Also consider the idea of bilinear interpolation.
Benjamin
Message 7 of 11
(7,936 Views)
Hi Trin,
it would furthermore be interesting how you represent your data in LV. Depending on your representation it could be possbile to use the "Mathmatics - Interpolation & Extrapolation - Interpolate 2D" function to solve your problem.
Benjamin
Message 8 of 11
(7,926 Views)
Hi Benjamin, thanks for replying, i guess what i need is the trilinear color interpolation since am working in 3D picture control. Well, still i didn't get any result out of color interpolation but trying to understand how they have done this in 3d sensor mapping. we ll see if it is going to work, still any idea or sample would be appreciated alot.
Message 9 of 11
(7,920 Views)
Hi Trin,
you really should try to break your problem into pieces. Do you want advise on your 2D surface interpolation task or on interpolation in 3D point spaces?
Better approach a single question at a time than try to solve everything at once.
Benjamin
Message 10 of 11
(7,913 Views)
