E4407B Spectrum Analyzer control
Dear all,
I was using the E4407B spectrum analyzer from made by Agilent company.
Also, I designed the LabView program to control the E4407B.
But it occurred to me some question.
Once i connect E4407B to LabVIEW program, i could not control the E4407B manually until i turn off it and turn on it.
Please let me know how to control E4407B manually while i connect E4407B to LabVIEW program.
Kwangbog Ham
NURI Telecom
Hardware engineer/Assistant Manager
(4,567 Views)
Accepted by Jackwelchi
Cycling power seems like overkill. Doesn't it have a button for local/remote? Read the manual for the preferred manual method.
To do it programatically, you might try sending the  GTL command or deasserting REN. Either is done with the VISA PPIB Control REN function.
(4,533 Views)
Thank you ,
I did search information website but i could not find it you recommanded.
Please let me know where i can find manual or GTL command or deasserting REN.
Kwangbog Ham
(4,516 Views)
Thank you,
I find it on NI website.
(4,513 Views)
Hi Jackwelchi,
May I have your labview program to control E4407B?
Thanks a lot.
(3,290 Views)
