ENET-9211and tpc-2106
Hello All;
I want to acquire data from 2 thermocouples using the ENET-9211 and want to display these data on the TPC-2106. Is this possible. If not, is there any alternative solution for this.
Thank you in advance for your assistance.
(2,551 Views)
NO, it is not possible. Usually, in this kind of issues, you should check what OS the TPC is running, in this case Windows CE.
Further, you should see if LabVIEW has drivers to support the devices you want to connect to the TPC, for windows CE.
The new National Instruments driver is called DAQmx, and usually, for Windows CE, DAQmx base is used.   http://www.ni.com/dataacquisition/companion_software.htm
The only issue remaining is the compatibility of ENET-9211 with DAQmx base. As you can see in the compatibility list below,
http://zone.ni.com/devzone/cda/tut/p/id/6913#ethernet, ENET-9211 does not work with DAQmx base.
An alternative sollution would be using USB-9211A, of course, depending on the length of the USB cable and the loss through it (usually 5m).
as you can see in the document below, the compatibility is solved
http://ftp.ni.com/support/softlib/multifunction_daq/nidaqmxbase/3.2/Windows%20Mobile-CE-XP-Vista/rea...
Mircea
NI Applications Engineer
(2,541 Views)
