How to bring shortcut of exe on deskto automatically after installation?
Can anyone tell me how to bring shortcut of exe on deskto automatically after installation?
Vijtin
(3,902 Views)
Find the picture attached which gives the procedure for adding the shortcut to desktop.
1. In the window for creating new installer select the "shortcut" option
2. Add a new shortcut using + sign
3. Select the shortcut folder as "Desktop folder"
4.Clear the subfolder text field to blank
This will add a shortcut to desktop after installation. CheersSmiley Happy
Message Edited by JK1 on 04-06-2009 05:32 AM
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(3,898 Views)
Ok!
that is cool.
but is there any option if i want the user to select if he wants the exe on the desktop at the time of installation?
like setting the property during run time
Ritesh
(3,855 Views)
Thanks jk,
Actually i m using labview7.0 so can you please tell me how to do it in labvie7.0...because in this i couldn't  get  "my installer properties" option.
vijtin
(3,831 Views)
I checked out the 7.1 installation setup but couldnt find such option.  Attaching the picture of the installer settings.
With regards,
JK
(3,819 Views)
