mp3 audio streaming in labview
Hi Guys,
I need to stream an MP3 audio from one PC to another PC via TCP IP network. I know that labview supports *.wav audio file format. But I need it for *.mp3 format. A step further, if you are able to provide solution for any type of audio format then that will be well and good for my application.
For your convenience I have attached both server and client VIs which I have used to stream the *.wav audio from one PC to another PC via TCP IP network.
Thanks in advance
MRK (CLAD)
Message 1 of 1
(3,686 Views)
