ENET devices on PXI
I'm limited to 8.6.1 for my project, although it looks like the same problem exists on LV2009.
MAX 4.6, NI-DAQmX 8.8, LabVIEW RT 8.6.0
My client wants to add a few ENET devices to the mix (already have SCXI, cDAQ, various TCP/UDP instruments, and various PXI boards in the system: 200+ channels).
I don't have the devices in hand, though I could get them if necessary.
In MAX, if I right click on the host's DEVICES AND INTERFACES, and choose CREATE NEW: NI-DAQmx Simulated Device, I get a menu with a category called "Network DAQ", from which I can choose the ENET-9211 or 9215 or the various devices I need.
But on the Remote System's (PXI's) part of the MAX interface, if I try the same thing, the menu does NOT include the Network DAQ category, and I cannot create a simulated ENET device.
My PXI has a PXI-8196 controller running NI-DAQmx 8.9.0
The architecture of my system is such that the PXI is the central collector of data, and the alarm manager, in addition to its real-time duties.
So what I want is for the PXI to operate the ENET devices, collect their data, check for alarms,  and merge it into the big blob of data that's already being sent to the host.
So, how do I get there from here? Can the PXI be the boss of the ENET devices?  Do I need a newer NI-DAQmx on the PXI box?
Steve Bird
Culverson.com
LinkedIn
Message 1 of 9
(4,217 Views)
Howdy Steve!
You will not be able to create simulated devices under Remote Systems section for your real-time PXI system.  If you create a simulated ENET under Devices and Interfaces (it will appear under the network devices section) then it will be on the same "network" even though it is fake.  I think if you simulate the ENET device via Devices and Interfaces you should be able to use it successfully during your development.
Barron
Applications Engineering
Message 2 of 9
(4,192 Views)
Well, that sounds promising, but it doesn't seem to work.
I do not have a "network devices" section in MAX.
When I run my little test program (which reads from "ENET1") on the host it's fine (I get a noisy sine wave, as expected).
But if I run it on PXI, I get Error -200220 : device identifier is invalid (ENET1).
MAX looks like this:
Steve Bird
Culverson.com
LinkedIn
Message 3 of 9
(4,180 Views)
Howdy Steve!
I realized that you will indeed need to upgrade to DAQmx 9.0 to have the Network Devices section.  Below is a screenshot from MAX on my machine (using DAQmx 9.0.2; VISA 4.6; MAX 4.6.2).  The description on the right states the need for DAQmx 9.0.  I apologize for not realizing this earlier.
MAX
Message Edited by The Red Barron on 05-28-2010 01:50 PM
Barron
Message 4 of 9
(4,165 Views)
Hmmm.  The official answer from Tech Support is that "you cannot do that".
Your idea that configuring from the host would allow the PXI to see it seems to be incorrect.
I quote:
I wanted to let you know that the ENET device cannot be configured for an
RT system altogether, as it is non-deterministic device. For this reason,
you are not able to simulate it for a remote RT PXI system.  You can use it
with your host PC, but not on the target device, which is why you can
configure it for your Local System. Unfortunately you will not be able to
use this device with your setup. Please let us know if you have any further
questions.
I don't see what determinism has to do with it: I'm running a CAN board, for crying out loud, and that is certainly not deterministic, in terms of when the samples come in.  I'm running several TCP instruments that are not deterministic.  I just take the latest values I have when it's sample time.
But there it is.  I can't get there from here.
Steve Bird
Culverson.com
LinkedIn
Message 5 of 9
(4,163 Views)
OK our messages crossed on the wires.  Is that MAX shot on a remote PXI system, or the host?  I can't tell from looking at it.
EDIT:  That has to be the host, as it has a PXI section below.
I hope that means that once configured, the device is visible from PXI.
Message Edited by CoastalMaineBird on 05-28-2010 02:05 PM
Steve Bird
Culverson.com
LinkedIn
Message 6 of 9
(4,161 Views)
Sorry, but that flat out does not work.
I copied the VM (I like virtual machines!!!) and upgraded the copy to NI-DAQmx 9.0f2
I also upgraded just NI-DAQ (not LV RT or anything) on the PXI box to 9.0f2
I now have the NETWORK DEVICES section within MAX, as you suggested.
I created the fake ENET1 device.
It works fine on the host,  but not from the PXI.
Same story: it does not see the ENET1 device.
How is the configuration (for example, naming it "ENET1") supposed to be seen  from the PXI, anyway?
Steve Bird
Culverson.com
LinkedIn
Message 7 of 9
(4,142 Views)
The more I think about it, the less I understand how what you say could possibly work.
I assume it's using TCP/IP and/or UDP, maybe that's my mistake.
If so, then somewhere, there has to be a translation table that turns "ENET1" into "192.168.0.123" or whatever the IP number is.
If I create the fake device on the host, then it can make up an IP number and tell NI-DAQ about it thru some config file somewhere.
When I ask NI-DAQ  to do something to ENET1, it looks up the number and sends the command.
But, unless you publish that configuration data ("ENET1" -->  "192.168.0.123") somehow out to the PXI, then the PXI's NI-DAQ has no way of knowing that there is such a beast as "ENET1".
Hence the error.
Steve Bird
Culverson.com
LinkedIn
Message 8 of 9
(4,137 Views)
You are correct that the screenshot I posted was from a host machine.  Also, you are correct that it will not be possible to configure the remote PXI target to communicate with the simulated device.  I had originally thought that this could be done, but after further testing it turns out that I was wrong.  As you stated the address translation prevents this from being possible.
Barron
Message 9 of 9
(4,064 Views)
