how to convert 8 byte hex to floating point double?
Hi
I want to know how to convert a 8 byte data string to a floating point double.
data (HEX): 40 02 4F 70 40 00 00 00
Thanks.
DP
(7,573 Views)
Accepted by topic author DDP_625
Is this 8-byte data string actually a string? Are the characters in the string the letters, or are you showing hex values? Ultimately you want to use Type Cast:
Message Edited by smercurio_fc on 06-01-2010 01:09 PM
(7,564 Views)
I think typecast is your friend:
Ton
My LabVIEW Ideas
(7,556 Views)
I often use this functions because I can select endianess for non Labview native data
Unflatten From String Function
Owning Palette: Data Manipulation Functions
Requires: Base Package
Converts binary string to the type wired to type. binary string should contain flattened data of the type wired to type. You also can use this function to specify the byte order, or endian format, of the data in the binary string.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(7,550 Views)
