EPICS-Labview communication
I completely agree with you.
However I do think that NI has made an important first step in the EPICS-LV communication, at least for simple beam line users such as myself.
If only the DSC module would be somewhat cheaper Smiley Wink
Steven
Message 11 of 43
(14,167 Views)
Steven hi,
I have look on NI shared variable. It looks shared variable mechanism doesn't support subscription/monitor. So your library can't support CA subscription Smiley Happy
Again this feature is not important in table system. But big control system can't accept this gap.
Andrei.
Message 12 of 43
(14,090 Views)
We are receiving a new control system implemented in Labview and I am
looking at interfaces with Epics. I found your post and thought this closely matach what we are trying to do.
SNS also offers a Shared Memory Interface to do this (http://neutrons.ornl.gov/diagnostics/documents/epics/LabVIEW/SNS_LabVIEWEPICS.html)
I'm compleltly new to labview: is the DSC from National Instrument a self contained solution (ie. it has the capability to setup and run an epics ioc server, hooked to some labview variables) or does it rely on external party software?
Thanks for any information,
Matthieu
Message 13 of 43
(13,844 Views)
We discussed 2 solutions of LabVIEW program (as client) - Epics IOC from somewhere (as server).
There are also 2 solutions LabVIEW program as server. One was implemented above ActiveX. Abother one is Shared memory interface.
It looks you need to change standalone  LabVIEW system into Epics server. I didn't use ActiveX solution, But I suppose Shared memory interface would be better.
Message 14 of 43
(13,831 Views)
The reason we want to setup the interface for our apllication is for simple monitoring purpose. The update rate is expected to be low rate (1Hz) and low volume (<100 values)
It looks both approach may work:
(1) a labview / ioc server that expose the labview data transparently
or
(2) a labview / ca client, that would `caput` values to some remote IOC and update dumb 'container' records
My requirement are not very stingent, because we lack expertise with Labview I am looking at the easiest / most practical solution. It also needs to be compatible with LabView 8.x
Any recommendations? and maybe some links where I can look at the different options? I only checked the SNS/server solution, but cannot find recent information for other options.
Also I read some thread indicating ActiveX / Labview CA might not be really supported.
Matthieu
Message 15 of 43
(13,828 Views)
Both men who wrote ActiveX and shared memory are working at SNS. ActiveX is not supported. Shared memory was supported a little and I don't know curently.
You can use any of your approaches..
If you have expirience with Epics IOC than LabVIEW client would be easy.
In another case Shared memory is eaier way.
Message 16 of 43
(13,820 Views)
so If I understand well, Steven has a 'client' solution implemented with NI / DSC module.
I would be interested to hear how I can implement that solution, if the code is available somewhere or if it's wrapped in the DSC package when you purchase it.
Matthieu
Message 17 of 43
(13,816 Views)
If I understand you correctly you have an application written with Labview 8.x and want to monitor some values that are accumulated somewhere and published on the net using EPICS.
I cannot comment on the shared memory option because I have no experience there. So here just a short note on the NI solution:
Assuming that on the EPICS side there is an IOC server available that is publishing the data on the net, you do not need any third party software. NI can provide you everything you need. I am currently working with a separate beta version of the EPICS I/O client server. Just contact NI and ask about the status of this beta version. Maybe it is already included in the DSC module. After this is installed just following the procedure I have described earlier. It is really very simple Smiley Wink
Cheers!
Steven
Message 18 of 43
(13,813 Views)
... or you can use my library Smiley Wink
You can take it from SNS (it is free), it is not use NI DSC (no money), works with LabVIEW 6.1 as minimum ...
Also you will not be simple ... monkey that click for your 100 values Smiley Tongue
In any case good luck!
Message 19 of 43
(13,812 Views)
Hi Andrei,
Can you send me a link where I can get hold of your interface? I contacted Willem who is listed as the SNS contact but did not get a reply.
Matthieu
Message 20 of 43
(13,737 Views)
