ERROR -301058 Ecu measuements
hello,
would like to read some variables CCP, but when I run the VI have this type of error. What can I do?
(3,283 Views)
Hello duglia,
Which device are you using in order to make this kind of measurement? Can you please take a look at the following document?
Why do I get Error -1074388957 while Using a NI-986x Series Module with ADCS or ECU MC Toolkits
http://digital.ni.com/public.nsf/allkb/5CDA6B0A892C921C862579600066A80A?OpenDocument
Antonios
(3,271 Views)
Hi Duglia,
I am facing the same error ERROR -301058 Ecu, when Iam trying to read the ccp variables using NI CAN (USB 8473).
The VI looks exactly same like yours.
So Did you find any solution how to read the data for the CCP variables using NI CAN.
If you have any vi which can communicate with NI CAN please attach it.
Thanks in Advance.
Madhan.
(3,244 Views)
