How do I generate multiple continuous digital signals into a DAQ 6259 device without the signals resetting, but at the same time I want to use the DAQmx method?
Hello I was just trying to figure by using the DAQmx method, how to generate multiple continuous digital signals into the pins of a DAQ device without the signals resetting. I would greatly appreciate the response.
(2,851 Views)
Hi EET9, what do you mean by “without the signals resetting”? LabVIEW already comes with examples that may help you achieving this task; you can check the examples by going to the help menu >> find examples >> Hardware Input & Output >> DAQmx > Analog Generation; and then select the example that better suits your application.
Eric NI
(2,836 Views)
Instead of the Analog Generation section of the examples you should probably look at Digital Generation, Digital Measurements, Generating Digital Pulses and Counter Measurements.
Though you should clarify what it is that you're trying to do as it isn't very clear from your post.
CTA, CLA, MTFBWY
(2,829 Views)
