ERROR
   This is sony
I have to interface USB to SPI bridge through Labview, i have imported all .dll files of the product, i can see all the functions related to this product under my library files, am getting the following error
Possible reason(s):
LabVIEW: An exception occurred within the external code called by a Call Library Function Node. The exception might have corrupted the LabVIEW memory. Save any work to a new location and restart LabVIEW.
          Can you please explain me about the error as well as the solution for the above error.
Hope your reply as soon as possible.
'' A professional is someone who can do his best work when he doesn't feel like it''...........
(3,602 Views)
Well, it seems that the dll is buggy or the call node is configured wrong, and there's not much LabVIEW can do about it.
What is the dll? How did you configure (import?)  it? What is your LabVIEW version?
(3,596 Views)
Thanks for your reply,..
                dll :  SLAB_USB_SPI.dll
Call library function node details :
    Function name : CP213x_GetUsbConfig
    Calling convention : C
I have to detect USB of this product.
(3,588 Views)
Do you have a link to the documentation?
(3,581 Views)
My Lab view Version : 10.0.1 (32-bit).
 Are you asking about the product documentation..?
(3,577 Views)
A few thoughts:
1.  Are you absolutely sure about the calling convention?  Choosing the wrong calling convention almost guarantees a crash.
2.  Another issue that often leads to a crash has to do with passing parameters incorrectly.  If you have arrays or structures this is likely an issue.  What is the function's signature?
3.  Can you access this DLL from another program (like perhaps a demo which came with it?) to make sure the DLL is actually OK?  A crash in the DLL function itself (unconnected to LabVIEW) would give similar results.
Batya
(3,520 Views)
