Open VI Reference LAN Help
Hi!
I have a LAN/TCP connection. On the side A, I have a simple VI, and I would like to call it from side B. How can I do that?
+++ In God we believe, in Trance we Trust +++
[Hungary]
(2,913 Views)
Hi Durnek,
The best is to use the Application Control palette, create a VI server on side A, on side B open a reference to the VI server with Open Application Reference Function, then you can access the VI with Open VI Reference and using the Invoke and Property nodes from the same palette you have access to a lot of information and settings.
Let us know if you have more questions!
Have a good day!
Patricia
(2,898 Views)
I have Server on one side that can be accessed from browser by typing ip 192.168.105.177       ,,,, so there is no vi on server side and I WANT ACCESS THIS SERVER FROM A VI IN OTHER SIDE.  what should I do ?
(2,832 Views)
