ESP300 PR50PP Stepper Motor Controller
Dear everyone,
I am a new learner of LabView. I learn how to use ESP300 to control PR50PP stepper motor through RS232 serial port. Would anyone can help me? Would you give me some LabView VI program to try?
Thanks a lot.
Smiley Happy
Message Edited by BelieverPaul on 03-26-2007 01:37 AM
(5,234 Views)
Hello BelieverPaul,
Here are some tutorials about programming with Serial.
Serial Instrument Control Tutorial
Instrument Control with the Serial Hardware Bus
Let me know if you need anything else!
Meghan
(5,213 Views)
Dear Meghan,
        You have given me a big help. I thank you a lot. I discover that I need to download CVI, VISA, INI too. I only install the LabView 8.2 that is not enough. Now I have try to configure the Serial Port.
And I have try to use the LabView program to send command ESP 300 that controll the PR50PP stepper motor. If you have any program, I will practise it.
Thanks a lot.Smiley Very Happy
Message Edited by BelieverPaul on 03-28-2007 03:23 AM
(5,203 Views)
BelieverPaul:
There are some example vi's available from Newport. I took a brief look at them, they are not well written nor documented. Not even sure thay are for Serial communication. You may want to look at them, but they may cause you more confusion than its worth.
Be sure to read the Download Instructions link on the page.
Good Luck
http://www.newport.com/store/genproduct.aspx?id=140199&lang=1033&Section=Downloads
(5,184 Views)
Hello BelieverPaul
I am a student in germany having the same problem. I am totally new to Labview and I want to talk to the ESP300 using RS232. I have Labvie 6.1 and 8.5 on my Labcomputer but I cant get the example.vi of NI to work. Can you help me? Have you written a VI I can use to control the ESP? Or do you have a commandlist?
To the ESP I have two UTS50CC connected.
Thanks a lot for your time and help.
crab
*Ariel is a hot babe and my friend :)*
(4,806 Views)
crab84 wrote:
Hello BelieverPaul
crab
That is a bit problematic since the drivers available from Newport do use the old style GPIB functions and are therefore completely unsuited for usewith RS-232. If those drivers would use VISA instead it would be fairly easy to modify them to support RS-232 too. But unfortunately!!!!
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(4,641 Views)
