ESPEC Chamber LAN Connection EXE Error
I want to control an ESPEC chamber via LAN. It works fine when I run it as a VI, however, I get error -1073807298 when I run the same VI as an executable.
This is the initialize VI where the error occurs:
(1,938 Views)
Hi alpha0,
Did you check the firewall settings?
You need to open the firewall for your executable, too…
(1,887 Views)
I temporally disabled my Windows firewall and still the same error. Are there other firewall settings that I have to change? Where do I do that?
(1,866 Views)
