ETS+SIT+real I/O
I'm trying to use an ETS PC with a PCI-6024E card and the SIT (simulation interface toolkit v2.0.2) in Labview 7.1 to run a simulink model embedded in it. That works fine I must admit, the problem is when I try to access the 6024 I/O to provide the model with real I/O.
I have followed the tutorial/guide from NI about the SIT but I can´t make out how to properly link the input/output of the model in matlab-simulink to the input/output channels in the 6024.
I understand that I have to include as many inputs/outputs in the simulink model as real I/O I want to use, so in the example of the tutorial I could use one input and one output. The problem is that I don't know how to do it.
I have configured the I/O channels I would use from MAX and I have performed some tests and they are ok. How could I connect them to the in ports of the simulink model?
Message 1 of 1
(2,488 Views)
