EXE crashing
Hi all
I am using labview 2015. I am using both VST(5840),VSA (5668r)
Now the problem i am facing is that whenever i make an EXE of any vi the EXE crashes after a while. This only happens when the EXE utilizes the VSA hardware . The EXE works fine when VST is utilized.
This problem occurs even with basic examples that are provided by the NI e.g the example of acquire spectrum are made into EXE and run.
I have not attached a snippet or vi as this error is occurring with every vi that utilizes VSA hardware. Error only occurs when running the EXE , simple vi runs completely fine even when ran for multiple hours
Thank you
(1,946 Views)
There is not enough info in the images to help you.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,860 Views)
Hi everyone.
To anyone facing this issue. The problem was the incompatibility of dll files of labview 2015 with new VSA (5668r). I upgraded my labview to version 2017 and the problem is resolved for now,
(1,790 Views)
