Unable to Launch LabVIEW NXG
I have installed LabVIEW NXG 5.0 in my PC and extended my evaluation to 45 days. In the license manager it is showing 45 days remaining. But when I launch NXG 5.0. A window is popping to activate NXG 5.0 and preventing the launch. Anyone faced this kind of issue. Kindly help. Thanks in advance.
NI License Manager Screenshot:
Activation Pop Up Window:
(2,461 Views)
Can you try using the LV NXG Community edition?
It ideally does not require an activation. The only thing you have to keep in mind is that, In order to activate through "Check my account for licenses," you must download Community Edition and activate using the same ni.com login.
Goutham
Application Engineer, NI
Goutham
(2,386 Views)
Goutham
Why even offer this as a solution or workaround?  If the user opted for eval, it's highly likely this will be used in a commercial environment and the user could very well get into legal trouble.
Bill
CLD
(Mid-Level minion.)
(2,376 Views)
