Each line in Digital port in different mode
hi I am using DAQ 6221 card. i want to set port0/line0 as input, port0/line1 as out put in the same way port1/line0:3 as input and port1/line4:7 as out put. give some idea to solve it. i attached my sample program. Regards hari
Message 1 of 11
(3,406 Views)
No attachment.
You simply use a different DAQmx Create Channel and task for the inputs and outputs. If using the DAQ Assistant, you would have two different ones.
Message 2 of 11
(3,395 Views)
hi i attached the file.
Message 3 of 11
(3,368 Views)
hi
Message 4 of 11
(3,365 Views)
hi
Message 5 of 11
(3,361 Views)
If you are trying to attach something, do not click on preview.
Message 6 of 11
(3,355 Views)
Message 7 of 11
(3,349 Views)
hi Its working with DAQ assistant. can you please solve my attached program.
Message 8 of 11
(3,329 Views)
As I said, you need to use two separate tasks. You are using one task.
Message 9 of 11
(3,320 Views)
hi you saw my program i used two create channels and one start task. what is the problem in that.
Message 10 of 11
(3,315 Views)
