Help acquiring a pulse via Ctr1 (in) from Ctr0 (out)
I am needing assistance acquiring a slow pulse signal.  I am generating a pulse using Ctr0 Out.  I want to graph this pulse output along with a temperature measurement to see how the two measurements interact.  My problem is that I never see the pulse at my pulse input channel.
I can measure the temperature fine.  this works good.  I can generate a pulse without a problem as I ave an O-scope to monitor the Ctr0 output.  this works fine.  However, I have wired the output of Ctr0 to a physical channel on the SCC-68 (PFI-4 or Ct1 Gate channel) and created a DAQ Assistant to acquire this pulse.  The VI runs and errors out with a message that the signal to the DAQ Assistant is never seen and thus times out.  I can physciall y see the signal via my O-scope going to the channel.  I must have the DAQ Assistant 2 configured incorrectly?????
Any input is greatly appreciated.
(2,604 Views)
Bump,  I am still stumped on this one.  Hopefully someone can quickly see what I am doing wrong.
CJ
(2,578 Views)
I noticed that your number of samples has been set to 1000 (continuous mode), hence a possible reason for the timout errors. I would suggest changing that to 1 sample (on demand) and see if that gives you any progress.
-Ciao 😉
(2,551 Views)
