Easier more elegant way to instantiating two CLIPs?
Unfortunately, I can't think of a good way to instantiate DMA FIFOs from the block diagram. They are strictly project items as well.
One design/framework that has been done to get around this is the register bus library
It's not really designed for streaming data, but basically provides a mechanism to route data through a single DMA channel to multiple parts of your design. It's a bit complex, but once you get the basics of the architecture, I think it's easy enough to use and implement. It may not really fit the requirements for your application if you're using the DMA channels for streaming large amounts of data.
Cheers!
TJ G
Message 11 of 12
(387 Views)
I'm going to mark the IPIL vs. CLIP comment as the solution even though I'm still investigating its implemetation.  I think that's going to fix me up though, I bet a large part of my issues are the difference between the way labVIEW handles the data dependencies
Message 12 of 12
(370 Views)
