Easy calibration??
Hi LabView people.
I am relatively new to the VI creation with LabView and have a simple question.
I am looking for an easy way of calibrating our SXCI-1001 chassis with the
1120 analog
amplifier and the 1328 terminal block. The one chassis is connected to a
MIO 16x and
the other to a "E" series board.
For our application we loath opening any hardware to do an actuall physical
calibration
on any instruments. We want to be able to just use them. The reference
onboard hasn't been
checked for some time now.
The question is is there an easy way of implementing a software calibration?
Currently
each individual VI has it's own set of scales and offset constanst built
in. This requires all
VIs to be calibrated. Whew more work than
a hardware calibration.
I would like to input my signals directly into the terminal block and do
the calibration as asystem.
I have made attempts to map out each channel with the NI-DAQ channel wizard,
but that
can also be time consuming. Though it seems to work very, very well.
Thanks to anybodying advance.
Darren
R&D, Test Technologist.
Message 1 of 1
(2,877 Views)
