Easy print VI Panel
Dear all,
I am using this code with the Easy print VI Panel or Documentation VI. My printer is a color printer but I always get grey scale print. What am I missing here?
Message 1 of 9
(5,969 Views)
Try to change quick print who use default values (?)
Message 2 of 9
(5,959 Views)
the printer options sets the printer to use and the printer options, if you want in color for example..... The VI uses this input only if report type is 0, that is if report type= quick print....
Message 3 of 9
(5,951 Views)
ok.. sorry i didn't understand..
I just say try to change quick print by standard for exemple..
Message 4 of 9
(5,944 Views)
If you use standard it will not consider the  color option.
Message 5 of 9
(5,938 Views)
Accepted by VincentKKM
before color/grayscale you use standard.. use unchange..  10th parameters
Message 6 of 9
(5,920 Views)
I think I fund a solution.
Message 7 of 9
(5,912 Views)
Message 8 of 9
(5,905 Views)
Is better? Cat Wink
Message 9 of 9
(5,901 Views)
