Easy print VI Panel
Dear all,
I am using this code with the Easy print VI Panel or Documentation VI. My printer is a color printer but I always get grey scale print. What am I missing here?
Message 1 of 9
(5,447 Views)
Try to change quick print who use default values (?)
Message 2 of 9
(5,437 Views)
the printer options sets the printer to use and the printer options, if you want in color for example..... The VI uses this input only if report type is 0, that is if report type= quick print....
Message 3 of 9
(5,429 Views)
ok.. sorry i didn't understand..
I just say try to change quick print by standard for exemple..
Message 4 of 9
(5,422 Views)
If you use standard it will not consider the  color option.
Message 5 of 9
(5,416 Views)
Accepted by topic author VincentKKM
before color/grayscale you use standard.. use unchange..  10th parameters
Message 6 of 9
(5,398 Views)
I think I fund a solution.
Message 7 of 9
(5,390 Views)
Message 8 of 9
(5,383 Views)
Is better? Cat Wink
Message 9 of 9
(5,379 Views)
