Easy question - Array indicator and control compatibility
I would like to multiply the contents of an array indicator by a factor (polimorphism allows the multiplication of an array by a number, right?) but the product requires that the array has to be a control.
How can I fixed this problem?. Thank you very much for your help,
javier
(3,242 Views)
Please see attached file to clarify my question.
Thanks Javier
(3,242 Views)
I removed the Indicator from the build array - it wasn't necessary. Also, your final array is now 2D. See attached, I believe its what you're asking.
Doug
(3,242 Views)
Thank you very much for your help. I used your example and added the function Index Array to convert the array to 1D.
Javier
(3,242 Views)
> control.
Unless you are using LV2, you can use local variables. The
control or indicator determines how it interacts with the
end user. To read from an indicator or to write back to
a control, popup on the object and choose Create Local, or
drop a local variable from the Structures menu and select
the object name.
Greg McKaskle
(3,242 Views)
