multithread application
Hi
I'm using LabView6i under Windows98.
I want to run a data acquisition application in 2 threads, application
and processing. I choosed "run with multiple threads" but can't see any
difference.
Can someone give me any hints how to design a multithread application?
Thanks Michael
(2,874 Views)
Michael,
Sometimes the difference is minimal, depends on all the operations being done by your different proceses. I believe if you have a system that can perform multi-threading, then the option should be selected. There is minimal overhead in the processor managing such, and the beneifts usually outweigh the small loss. The attached link is a very good source of thread info.
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&75C636329327A87B862568690074800A&cat=8ABEC12D4C0AA4A3862567AC00583899
Good Luck with it, Doug
(2,874 Views)
