Easy way to compare sw versions between PC's
Hi
Is there a easy way to compare sw versions between PC's
I can see versions in MAX, but it is cumbersome to compare between a lot of PC's manually.
Regarsd Bjarne
(2,199 Views)
You might want to have a look at SystemLink.
GCentral
(2,151 Views)
Thanks Crossrilz.
SystemLink is the gold-plated solution and unfortunately not fitting into our current system. 🙁
I found a vi (Get installed Software) that help me to compare.
regards Bjarne
(2,078 Views)
